Results 1 to 7 of 7
    Over the Hill
    Reputation: Club Mud's Avatar
    Jan 2011
    Are Shimano and SRAM/Truvativ, 2x10 chainwheels interchangeable?
    I want to install a 24t 64mm BCD inner on my SRAM X9 2x10 crank, but I don't see any available. Are the shimano (available) 24t rings a good fit? Anyone seen the SRAM 24t available anywhere? Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Club Mud View Post
    4-bolt 64BCD is 4-bolt 64BCD no matter who makes it.
    mtbtires.com
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    umm not shimano's stuff is kinda different than anyone elses. Srams are all standard and you can get any basic after market chain ring to fit. look at BlackSpire.. you can go to their web site but if ya search the web you can usually save a few buck. they are wicked good about customer service also and you can call and ask to verify what ring will work on your cranks.
    Just so you know, the "BCD" on them all is the same, just Shimano makes the shoulder the chainring and spider match slightly diff from everyone else. you actually can file it a bit and make them work, but it's a tad weaker and more times than not it'll end up creaking under load.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Dec 1998
    Quote Originally Posted by thomllama View Post
    There is no shoulder for inner rings
    mtbtires.com
    Oct 2007
    Quote Originally Posted by shiggy View Post
    oh ya.. thats true
    Over the Hill
    Jan 2011
    Thanks, everyone. As a machinist and engineer I know the 'standard' numbers should tell all, but without having the two in hand to compare details such as hole and counterbore diameters and overall thickness, I'm not positive about compatibility. But your answers encourage me to buy one and try it.
    Dec 1998
    Bolt hole diameter is standardized.
    Counter bores are not needed on the inner ring.
    Thickness matters little, especially with a double, and 9-/10-sp are interchangeable.
    Shifting is fine despite what Shimano/SRAM want you to believe. Ramps/pins have almost no affect on the inner ring (I still use and prefer straight tooth rings in all positions).
    mtbtires.com
  1. SRAM XX or Shimano XTR 2X10?
    By NorCal Biker in forum California - Norcal
    Last Post: 07-24-2013, 09:05 AM
  2. SRAM 2x10 crank with Shimano 2x10 system
    By Vhom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 12:42 PM
  3. Are SRAM and Shimano 10 speed shifter/derailleurs interchangeable?
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-06-2011, 08:47 AM
  4. SRAM Twist XO with 2x10 Shimano or SRAM front derailleur
    By epiphreddy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2011, 08:52 AM
  5. truvativ hussefelt crank with sram 2x10?
    By jcatier314 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2011, 10:41 AM
