Results 1 to 6 of 6
    Shimano/SRAM Compatabilty
    My crank requires shimano chains and I am thinking of upgrading to a SRAM 9-speed system. My question is whether a shimano chain can work with a SRAM cassette? Also, I remember reading that when you replace a chain you should also replace the chain rings, is this true? Thanks for your help.
    Why does it require a shimano chain? A chain is a chain, 9 speed is 9 speed. If you want to use a Shimano, SRAM, Wipperman or KMC chain they will all work as long as they are all 9 speed.
    If you've put a bunch of miles on your chainrings, it couldn't hurt to swap them out either.
    There is a sticker on the largest chainring that says, "Shimano IG Chains Only". So, do i need a Shimano IG chain? If so, will the shimano ig chain work on the sram casette?
    Reputation: flipnidaho's Avatar
    Quote Originally Posted by JP Page
    As robdamanii said, you can use any brand 9spd chain on SRAM or Shimano 9spd drivetrains.
    Thanks for the help. Is there a reason they designate the IG chain on the chainring? Is it something for 8-speed only?
    so you would buy shimano chains and they can make even more money...
  1. Sram x9 rear derailleur + Sram x7 shifters + shimano cassette (Shifting all messed?!?
    By Angus_fairgrieve in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2015, 05:05 PM
  2. Replies: 10
    Last Post: 03-17-2007, 02:19 PM
  3. Sram / XTR / XT / Sram & Shimano
    By eischman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-26-2005, 06:00 AM
  4. XO Rear DR / XT 11-34 cassette compatabilty?
    By scepticshock in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-01-2005, 04:40 PM
  5. x.9 Sram Setup, Shimano XT cassette, or sram?
    By Slowjett in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2004, 05:04 AM
