Results 1 to 7 of 7
    Feb 2013
    shimano SLX rear derailleur delay in shifting
    when i shift to the smaller cogs it takes a few revolutions to complete a shift. can you guys help me how to fix this
    thanks
    Reputation: Nater's Avatar
    New cables and housing.
    Trail Ninja
    Reputation: Varaxis's Avatar
    ^ my suggestion as well, with new cables and housing, without knowing more details.
    We're all on the same ship, and it's sinking.
    Reputation: J.B. Weld's Avatar
    First thing to try is turning the cable barrel adjuster in about 1/2 to 1 turn.
    I'd first check that cable tension is adjusted optimally. If that doesn't fix the sifting problem then maybe new cables are the right choice.
    Half our life is spent trying to find something to do with the time we have rushed through life trying to save
    Feb 2013
    thanks for the replies. the SLX does not have a barrel adjuster on the derailleur. can i use the one on the shifter? which way should i turn?
    Quote Originally Posted by bowser29r View Post
    Yes, you can use the one on the shifter. Clockwise.
  1. Rear derailleur shifting problems
    By muell in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-14-2012, 07:01 AM
  2. Rear derailleur shifting problems
    By ibchoux in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2012, 09:05 AM
  3. Slow rear derailleur shifting
    By Cevan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-07-2012, 10:47 AM
  4. Another Rear Derailleur Shifting Question
    By cattledog04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2011, 12:06 PM
  5. Shifting is 1 gear off on rear derailleur...help!
    By AirricK11 in forum Beginner's Corner
    Last Post: 06-05-2011, 11:54 AM
