Results 1 to 2 of 2
    Reputation: zanq's Avatar
    Shimano SL-BS78 (10sp) barend shifters compatible w/ 9sp in indexed mode?
    I'm looking at Paul Thumbie adapters and a set of Shimano bar end shifters for a mtn build. I've learned that the newest 10sp bar end shifters (SL-BS79) are index only. The SL-BS78 version is 10sp and both indexed/friction.
    I was hoping to run a 9sp rear der. and cassette with the option to go 10sp if/when I need to. Is a 10sp shifter like this compatible with 9sp in indexed mode? I'm pretty sure friction mode will work but I want the indexed shifting. If not, I'll have to look around for a set of BS77 shifters.
    Ventana El Rey - 3x9
    Schwinn High Plains w/ drop bars - 3x8
    Surly Ogre - Alfine 8/SS
    The 10 speed bar ends will work indexed with a 9 speed rear derailleur and a 10 speed cassette. You have to change the cassette.
    Road shifters/derailleurs did not change between 7-8-9-10 speed so 9 speed MTB rear derailleurs have to be used with 10 speed road shifters.
  1. X9 10sp rear der w/ 9 sp shifters?
    By Mike E. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2012, 01:35 PM
  2. Shimano XT SL-M770 10sp Dyna Sys shifter with RD-M780 rear derailleur - compatible?
    By jzt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2011, 09:50 PM
  3. Shimano 105 10sp vs MTB shifters ???
    By elpoocho in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-04-2011, 07:32 PM
  4. Best lube for indexed shifters?
    By marpilli in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2011, 02:50 AM
  5. Shimano Flight Deck - compatible with XT Shifters SL-M760? YES IT WORKS!
    By aa240sx in forum GPS, HRM and Bike Computer
    Last Post: 04-19-2011, 09:00 AM
