Results 1 to 3 of 3
    Reputation: AmericanTemplar's Avatar
    Shimano Saint RD-M810 set up difficulty!
    So I was trying to install the M810 tonight and was having some difficulty. I think that the main problem lies in the fact that my derailleur hanger (not replaceable) is too thin for it. When I tightened the fixing bolt all the way down, it stuck out the back and the chain hit it when it was in the small cog. My old XTR has a c-clip as a spacer on the fixing bolt that I was going to try to move over onto the Saint but it didn't fit. Should I just get a washer or will that affect shifting?
    As long as you have enough range of motion via the limit screws, there shouldn't be a problem. Pick up a thin nut to take up some of the thread on the inside of the frame, too, as it sounds like you have quite a bit.
    The thin nut idea is a good one! Unfortunately, I was unable to find one that would fit at the two hardware stores that I went to so I ended up going with the washers. Hopefully I'll be able to get it working tonight!
  1. Can I use the Shimano Saint M810 SS 9-spd derailleur with a 12-36 cassette?
    By eurospek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2014, 09:00 PM
  2. Replies: 7
    Last Post: 10-22-2012, 05:25 PM
  3. Shimano M810 Saint Brake Help
    By Highwaystreets in forum Shimano
    Last Post: 08-07-2012, 06:14 PM
  4. Shimano saint br-m810
    By Iwanttorideatnight in forum Brake Time
    Last Post: 04-04-2012, 03:45 AM
  5. M810 Shimano Saint rear hub dimensions?
    By Olie12 in forum Wheels and Tires
    Last Post: 04-30-2011, 08:56 AM
