    May 2013
    Shimano problems
    I just squirted chain lube on the rear mech of the Shimano Acera. Now it won’t stay in the low gears, but gradually makes its way through the gears to 7th gear without any action on my part. Any suggestions much appreciated.
    Cheers
    Peter
    Ok, when it goes to 7th gear, will the shift lever return it to 1st?
    If so, I'm guessing you have a shifter problem that occurred either by coincidence or because the cleaned and lubed rear derailleur is allowing the spring to pull harder on the cable, causing the shifter to slip.
    Try removing the cover from the shifter and cleaning it. I use aerosol Dupont Chainsaver lube from WalMart for this sort of thing.
    May 2013
    Shifter
    Sure, it returns to 1st gear OK, I just have to hold it in place to prevent it returning down the scale. It's one of those dreadful twist gear changes on the handle bar, which probably doesn't help.
    Peter
    Quote Originally Posted by DennisF View Post
    Yeah, I have an old bike with SRAM twist-grip shifters. There is a flat spring with a V in the middle that is supposed to click into a notch on a disc and hold it in place. The spring gets weak or the notches wear. It could be dirt interfering too. Nothing to lose by taking it apart and cleaning it or trying to bend the spring a little.
    Or order this
    Shimano Acera SL-M310 Rapid Fire Shifter, Right (Black, 7-Speed) : Amazon.com : Sports & Outdoors
    Shimano SL-M310 Acera Shifter Right (8 Speed) : Amazon.com : Sports & Outdoors
    I don't know that much about it -- someone else can confirm -- any Shimano shifter with the correct number of gear settings should work so long as it is not DynaSys.
  1. Shimano XTR M988 problems
    By hisbabyf in forum Shimano
    Last Post: 08-02-2012, 08:09 PM
  2. Shimano XTR 2x10 chain problems? cage?
    By Mozzer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-22-2011, 01:19 PM
  3. Shimano alivio cleaning questions/problems
    By betelgeuse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2011, 04:17 PM
  4. Strange Shimano disk brakes problems
    By johna7770 in forum Brake Time
    Last Post: 03-08-2011, 09:05 AM
  5. Replies: 7
    Last Post: 01-10-2011, 08:39 PM
