    shimano hg40 cassette will it work with IG chain
    shimano hg40 cassette will it work with IG chain//
    Here is my issue I have an hg 40 cassette and IG only crank set I do have an IG
    chain will it all jive or should I dump the hg40 cassette?
    Reputation: GearHead's Avatar
    Dec 2004
    Good job! Its good!
    From Shimano's FAQs:
    Can I use an IG chain with a HG cassette?
    "All current HG cassette cogs are specifically profiled to be HG or IG chain compatible. Any Shimano IG chain will work with any HG cassette. If you use a HG chain with a 7-speed IG cassette the rear derailleur adjustment becomes more critical. Always avoid using a HG chain with IG-only crankset."
    I could not find that Thanks a lot
    Do you think 34 theeth will make for a better uphill (steep) climbs?
    Dec 2004
    Cassette Gearing
    I like to climb really technical steep hills and have never found use for anything larger than a 32 tooth max on cassette, which I only use if I am middle ringing it. If I am in the granny ring I would only ever use 24 tooth or very rarley the 28 tooth on cassette. Lower gears seems to reduce rpm too much for my liking. Also, you will need to add more tension with the spring adjustement screw on the derailleur so the top G-Pulley on the derailleur doesn't make contact with your cassette when in the low gears, as well as add more length to the chain to cempensate for the larger change in gear ratios. Both of these make the rear derailleur shift slower any other time. That being said, I wouldn't not use a 34 tooth if you already had one, but I don't see any benefits with them.
  1. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  2. Very Old Shimano 7 speed replacement
    By NFields in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-27-2004, 04:30 PM
  3. Disciples of trail work
    By General Coonskins in forum Oregon
    Last Post: 04-26-2004, 06:20 PM
  4. Replies: 3
    Last Post: 04-19-2004, 05:56 PM
  5. Does SRAM PC99 chain & SRAM PG-990 cassette work with 01 XTR??
    By LocoMotoMan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-16-2004, 10:10 PM
