Results 1 to 1 of 1
    Jun 2005
    Shimano FC-M540-L Crankset and Help a noob
    Hey people...
    Show me what you know please... Your knowledge is great im sure
    I got a nice used Specialzed M2 Metal Matrix (1998 I think) MTB and decided to replace the the crankset. My bike came with a typically worn set Sugino Css III gears and Specialized Strongarm cranks (not sure what the BB is.) I bought a set of new Shimano FC-M540-L (Coded as "Deore" on the shimano website) with Hollowtech Octalink cranks and a shimano Es-30 bottom bracket for 60$us. I commute to my University and will start to hit the occasional easy trail.
    Good Replacement? Indifferent? Worse than what I had?
    Hopefully it's no worry... If i made a noob mistake then so be it. One of the reasons i ask is that i saw my old crankset sell for 67 bucks used on ebay today... but im balancing that against the fact that im seeing this shimano crankset on decently high end bikes (see links below.) So essentially all things being equal, i can sell those and break even whilst still upgrading to a NEW crankset.
    Thanks in advance! - Battle
    Bikes where Shimano FC-M540-L is appearing
    Scott Genius MC50 (2005) 1,499.99
    Avanti Hammer (2005) $1,919.00au
    Shimano FC-M540-L Features
    HOLLOWTECH crank arm construction
    Mega-9 gearing compatible chainrings
    DUAL SIS compatible
    Gearing:44T-32T-22T
    OCTALINK BB Mount Interface
    Specifications
    HOLLOWTECH
    Crank Arm
    Splined OctaLink Mount
    4-Arm Chainring
    Chain Super Narrow HG
    Number of Teeth 44-32-22T**
    Bolt Circle Diameter 104/64mm
    Crank Arm Length 170/175mm
    Crank Arms forged aluminum/hollow type
    Outer Chainring aluminum
    Middle Chainring steel
    Inner Chainring steel
    Chainring Bolts & Nuts - stainless steel (bolt), steel (nut)
    Chain Guard
    FC-M540-L/M540-LK:44-32-22T
