Results 1 to 2 of 2
    Shimano dual control lever question
    I've just replaced the rear gear cable on a shimano XT dual control system, and now the lever is not shifting up properly, it shifts up when you pull it towards you, but doesn't return to the neutral position. Sort of stuck down I guess.
    Any tips on what could be the problem? Thanks in advance for any advice.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Are you sure the cable end went correctly into the fitting and is not interfering with the mechanism? Did you make sure to reset the shifter all the way down before inserting and tightening the cable on the derrailleur? How old are these shifters?
  1. need your final advice on xtr dual control......
    By marco in forum Weight Weenies
    Last Post: 09-05-2005, 08:21 PM
  2. Replies: 2
    Last Post: 04-22-2005, 09:22 PM
  3. Wonder why Shimano Dual Control Bombed in the UK?
    By Slartibartfast in forum Passion
    Last Post: 03-29-2005, 06:38 PM
  4. XT Dual control lever with Avid Mechanical DIscs?
    By the_eleven in forum Brake Time
    Last Post: 05-29-2004, 04:21 PM
  5. Shimano disc lever question
    By indigosky in forum Brake Time
    Last Post: 05-11-2004, 01:24 PM
