Results 1 to 8 of 8
    Jan 2005
    shimano deore rear shifter
    it came apart on a ride today, i think i got all the parts that fell off..there's a lock nut in there that came loose....i went to the shimano site, but they don't give a complete diagram of how all the parts go together
    has anybody rebuilt thiers or know where i can find a complete diagram of how to put it together
    i'm stuck in a high gear too,
    please help, thanks
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    Wolf nipple chips
    Reputation: Cabin Fever's Avatar
    i can tell you one of two things:
    a) buy a new one, as Deore isn't all that expensive
    b) good luck!
    Jan 2005
    took an hour or so to figure out that i did loose a piece out on the trail...salvaged the piece from another bike...got the shifter to work again....not hard to figure out...but they don't sell parts so they don't want people doing this..chalk it up...but i can ride tommorrow
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    The rapid-failure (sorry - couldn't resist), ahem, rapid-fire shifters were never intended to be user servicable. When they croak, Shimano wants you to buy a new set. Service parts and information aren't available.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Zanetti
    Oops, what are these then?
    Yes, not all the parts are available, and they aren't intended to be taken apart and put back together. It's kind of like a 3 speed hub, it can be taken apart and put back together, but you better remember what order you took out the parts in, so you get them back in correctly.
    LD8508
    16
    STM800/760-5 Left Hand Release Lever & Fixing Bolt Saint M800; XT M760,765
    LD8509
    29
    STM800 STM760/5 Shifting Cable Adjusting Bolt Saint M800; XT M760,765
    LD8499
    12
    STM800/765/760 Right Hand Lever Cap & Fixing Screw Saint M800/XT M760/M765
    LD8500
    23
    XT ST-M760/5 Left Hand Lever Cap & Fixing Screw Saint M800/XT M760/M765
    LD8501
    10
    XT ST-M760 Right Hand Top Cover & Fixing Screws XT ST-M760
    LD8504
    12
    XT ST-M765, ST-M760 Left Hand Cable Cover XT ST-M760, M765
    LD8506
    12
    XT ST-M765, ST-M760 Left Hand Bottom Cover Unit XT ST-M760, M765
    LD8507
    24
    STM800/760-5 Right Hand Release Lever & Fixing Bolt Saint M800; XT M760,765
    LD0926
    XTR ST-M965 Right Hand Main Lever Assembly XTR ST-M965
    LD0928
    6
    XTR ST-M965 Left Hand Main Lever Assembly XTR ST-M965
    LD0930
    7
    XTR ST-M952 left Shift Pod XTR ST-M952
    LD0931
    10
    XTR ST-M952 Rear Shifter Pod XTR ST-M952
    LD0932
    14
    XTR ST-M952 left shift indicator XTR ST-M952
    LD0933
    20
    XTR ST-M952 Right Indicator Unit XTR ST-M952
    LD0942
    50+
    XTR ST/SL-M952 Derailleur Cable Adjuster Unit XTR ST-M952
    LD0944
    24
    XTR SL-M952 left indicator unit XTR ST-M952
    LD0945
    20
    XTR SL-M952 Right Indicator Unit XTR ST-M952
    LD0953
    XTR ST-M960 Right Side Main Lever Assembly XTR ST-M960
    LD0954
    5
    XTR ST-M960 Left Side Main Lever Assembly XTR ST-M960
    LD0991
    10
    XTR ST-M960, ST-M965 Right Side Indicator Unit XTR ST-M960,965
    LD0992
    13
    XTR ST-M960, ST-M965 Left Side Indicator Unit XTR ST-M960,965
    LD0993
    19
    XTR ST-M965 cable cover and fixing screw right ride XTR ST-M965
    LD0994
    22
    XTR ST-M965 Cable Cover and Fixing Screw Left Side XTR ST-M965
    LD0995
    9
    XTR ST-M965 Shifting Cable Adjusting Bolt Unit XTR ST-M965
    LD0996
    41
    XTR ST-M965 Release Lever Unit Right Side XTR ST-M965
    LD0997
    22
    XTR ST-M965 Release Lever Unit Left Side XTR ST-M965
    LD5837
    Discontinued
    LX ST-M570 Rear 9spd Shifter Pod LX St-M570
    LD5838
    Discontinued
    LX ST-M570 Left shift Indicator LX ST-M570
    LD5865
    7
    LX SL-M570 Left Indicator Unit LX ST-M570
    LD5866
    50+
    LX SL-M570 Right Indicator Unit LX ST-M570
    LD6073
    Alivio MC-12-c Left Indicator Unit Alivio MC-12
    LD6624
    31
    XT/LX/STX-RC R/fireSL Shift Cable Adjuster XT St-M739,740; LX ST-M567; STX and STX-RC ST-MC34,36
    LD8414
    33
    XT SL-M750 Left Indicator Unit XT ST-M750
    LD8415
    14
    XT SL-M750 Right Indicator Unit XT ST-M750
    LD8425
    6
    XT M750 Front Shifter Pod XT ST-M750
    LD8426
    20
    XT M750 9spd right Shifter Pod XT ST-M750
    LD8427
    18
    XT M750 Left shift Indicator XT ST-M750
    LD6326
    XT ST-M765 left hand top cover & fixing screws XT ST-M765
    LD8505
    12
    XT ST-M765, ST-M760 Right Hand Bottom Cover Unit XT ST-M760, M765
    BR2501
    43
    XT ST-M760 Brake Cable Adjusting Barrel XT ST-M760
    LD6325
    XT ST-M765 right hand top cover & fixing screws XT ST-M765
    LD8502
    13
    XT ST-M760 Left Hand Top Cover & Fixing Screws XT ST-M760
    LD8503
    8
    XT ST-M760/5 Right Hand Cable Cover XT ST-M760, M765
    LD8344
    Out of stock
    XT ST-M765 Left Hand Main Lever Assembly XT ST-M765
    LD8349
    XT ST-M765 Right Hand Main Lever Assembly XT ST-M765
    LD0999
    Out of stock
    XTR ST-M961
    LD1000
    8
    XTR ST-M961
    LD1002
    Out of stock
    XTR ST-M966
    LD1003
    XTR ST-M966
    LD7007
    10
    Deore XT SLM751 Cable Adj Assembly XT SLM751
    LD7009
    Deore XT SLM751L Left Indicator Unit (Black)
    Every last one of those parts (with QBP #) is either the entire shift pod assembly or random plastic parts - like the levers, indicators, attching parts or trim. See if you can get a relese pawl or spring out of shimano or see if QBP actually has any of them in stock - several were listed as "discontinued".
    I stand by what I said.
    Jan 2005
    yeah, these parts are just the 'easy' ones...the internal stuff, a piece of which i lost, would be nice to order but they don't want you to...if i could buy the part, i know how to disassemble and reassemble...these are a lot easy than the ones back in the early '90's
    anyway
    Chrome Toaster
    Reputation: Hecubus's Avatar
    While a lot of the internal guts are not meant to be user serviceable, within reason a lot of the parts are replaceable even if they are sold as full assembly chucks. Fortunately shifter pods will rarely ever break down. A good cleanup is all they usually need to overhaul them. Unfortunately Deore shifters are not exactly designed to be all that durable. They are practically entirely made of plastic and the shipping cost for a replacement part would be about the same as the cost for a full new shifter. You can probably buy a full new one for the cost of replacement parts.
