Results 1 to 5 of 5
    Mar 2012
    Shimano Deore rear der. and Sram X-7 shifter
    Are these compatible? Lbs says they don't think so. Anyone have experience with this?
    Jul 2003
    No they are not. Shimano and SRAM derailleurs and shifters use different cable pull ratios for their rear d's. Front derailleurs are compatible between the two manufacturers, rears are not. So you if you have a Shimano rear d, then you need a Shimano shifter, and vise-versa.
    Good Dirt
    Former Bike Wrench
    Not compatible unless you use an adapter which costs about as much an X7 rear derailleur or Deore shifters.
    Jtek ShiftMate Straight
    Mar 2012
    sram uses 1:1 ratio, shimano 2:1.
    Mar 2012
    Thanks guys. Just wanted to make sure.
