Results 1 to 6 of 6
    Shimano crank with sram components?
    Hey guys, I was wondering if its possible to run a shimano crank with x9 components and run a 2x10 configuration and remove the bigger cog on the shimano m770 crank. Just because I heard some really bad review on here about the sram X.9 crankset.
    Jan 2011
    I ran a Shimano SLX Crank but 1x9 with Sram X9 Rear der. and X9 Shifter with no problems at all
    Alright I really want to do 2x10 for this so I was thinking take one ring off and use a sram x9 front der. and shifter. I just wanted to make sure everything would align good and nothing would get stuck.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    I also have a Shimano crank with SRAM components, it's perfectly fine.
    Never trust a fart
    Reputation: frdfandc's Avatar
    I'm running a SLX 2x9 with the remainder drivetrain being SRAM. Works perfectly.
    Not a problem for these parts to work together . The chain wheels and spacing is compatible between the two companies.
  1. SRAM X-7 vs Shimano components?
    By DanMach86 in forum Specialized
    Last Post: 09-09-2008, 09:12 AM
  2. Is it alright to mix Shimano and SRAM components?
    By nujer99 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-06-2007, 10:59 AM
  3. SRAM vs. Shimano Components
    By shyatt3 in forum General Discussion
    Last Post: 05-03-2007, 06:54 AM
  4. Sram chains with Shimano drivetrain components?
    By MTB1986 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2006, 05:23 PM
  5. Shimano Alivio to SRAM components
    By phazer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2005, 12:58 AM
