    Reputation: rockman's Avatar
    shimano chainring question-hollowtech 1vs2
    Would a M760 32t chainring be interchangable or compatible for the m752 chainring that was originally on a hollowtech I era crankset? The ramps and pins are somewhat different but I'm not sure about the spacing. Any input appreciated.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Yes. Both cranks are 104 BCD. Only problem I see is that some of the chain rings have a little extra material so it doesn't sit flush on the crank. Sometimes it just needs to be filed down a little bit.
    dot
    dot is offline
    Reputation: dot's Avatar
    Quote Originally Posted by rockman
    No, they're different. The inner diameter of the newer middle ring is a bit smaller.
    You need to file off some metal from inner edges to install it on a older (H1) system. Unfortunately, I've just discovered it through practical experience.
    thanks for the reply,
    I had the newer one lying around for some reason and no way to return it so I thought I'd see if it would work. Shimano rings are not cheap but this 1st generation hollowtech crank/bb is still going strong.
