    New question here. Shimano BB-M952 fit FC-M752 ?
    I've been asking around and did some research but still not fully sure if the 2 will fit together.
    Can anyone tell for sure if the above-mentioned BB & crankset are compatible?
    My BB shell is 68mm wide.
    Jason
    Reputation: heatstroke's Avatar
    Jul 2003
    no , xtr and xt octalink are different
    Chrome Toaster
    Reputation: Hecubus's Avatar
    No they are not compatible. The 952 XTR BB uses what is known as the V1 octalink splines. Its splines are only 5mm long and require a crank arm with the matching interface. Their roadbike cranks share this design. The XT type octalink has longer splines, about 10mm long. I'm pretty sure the 752 cranks would fit into the V1 type spline but the engagement area between the BB spline and cranks grooves will be so small it will strip the crank arm mount.
    Good job! thanks guys...
    for your confirmations. I had thought that the 2 Octalinks looked the same and almost bought the BB to replace old one.
    Jason
  1. New to the sport, need bike :)
    By iLLestOne in forum Bike and Frame discussion
    Last Post: 05-13-2005, 06:28 AM
  2. Can I use a 73mm BB with a 68mm cup to fit my frame?
    By fran in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2005, 11:37 AM
  3. Shimano Deore Cranks w/ stock BB? (shimano BB-LP-28)
    By phil. in forum General Discussion
    Last Post: 02-15-2005, 07:13 AM
  4. Shimano LX M752 & BB
    By tron in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-14-2004, 09:12 PM
  5. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
