Results 1 to 5 of 5
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    shimano 8 spd barcon w/ 105 FR & MTB Crankset
    Im building up a cx bike. I want to use a truvativ MTB triple with an existing 105 bottom pull FD controlled by a shimano 8 spd barcon..will this work..well?
    Suggestive alternatives are welcome..the CHEAPER the better...
    Thanks in advance..
    Linoleum Knife
    Reputation: forkboy's Avatar
    Quote Originally Posted by jrm
    Thanks in advance..
    Which 105 front derraileur do you have? There is a triple and a double 105 FD.
    FD-5500 - double
    FD-5503 - triple
    The fd5500 may have problems going far enough out to use your triple.
    jrm
    jrm is offline
    its the FD-5500 im pretty sure..
    So are you saying that the barcon and crankset should work WELL if i get a FD 5503?
    Linoleum Knife
    You sound like you are going to hold me responsible for my opinions
    If you've got to buy a new derr., I would get a mountain derraileur. The shimano mountain and road (and SRAM for that matter) shifters pull the exact same amount of cable per shift on the front derr.
    I would personally try fiddling with what you got to see if you can make it work before spending unnecessary cash. Mess around with the limit screws and see if you get it to go out far enough.
    jrm
    jrm is offline
    Thanks.. thats what im working towards
    In my response i just wanted to make suetha the other parts were compatable and that the FD was the thiung that i needed to focus on. Thanks again...
  1. Do 8 spd chains work on 9 spd systems?...
    By Gnarlygig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-07-2004, 09:18 AM
  2. Beginner, want a FS bike, which one?
    By Rich4757 in forum Bike and Frame discussion
    Last Post: 05-31-2004, 07:40 PM
  3. 9 spd. rear der. work with 8 spd. stuff?
    By bikebreath in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2004, 09:46 AM
  4. Upgrading 9 spd Crank to 8 sp Drivetrain
    By toneetouch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2004, 06:43 PM
  5. 8 spd rear der with 9 spd drivetrain
    By jakey in forum General Discussion
    Last Post: 04-01-2004, 11:19 AM
