After a few rides I needed to give my bike a quick cleaning and tune. I almost have the bike shifting great with a small issue.
The issue is when I click the shift lever, either up or down, nothing happens at first. I need to click it again then it will start to shift somewhat properly. The somewhat is when shifting to the larger gear rings in the back the second to largest gear is totally skipped. The only way for me to access that gear is to shift back to it after passing it.
Is this just a simple cable tension problem or something else? I'm just getting frustrated trying to make it right so any suggestions are well appreciated. Thanks
Bike is a 2006 Iron Horse Warrior Comp
