Results 1 to 33 of 33
    Shifting help please!
    I'm trying to hone in the shifting on a new bike and simply can't get it. I have a 9 speed cassette. I set up the derailleur, a 9 speed xt reverse pull derailleur so that the limit stops are aligned under each outward cog. I made the cable as tight as possible while having the barrel adjuster in the most relaxed position.
    As I shift through, I've gotten to a point with the barrel adjuster where if I relax it one click, it isn't taught enough to go to the hard, smaller cogs. If I tighten it one click, it will go to the harder, small cogs, but won't go all the way back up to the larger, easier cogs.
    I've reached a point where it seems I have no more room for adjustment. I'm still getting a lot of skipping and irregularity with respect to the chain reaching the ends of the spectrum, despite the fact that the limit stops seem to be set perfectly and the barrel adjuster seems to be right where I need it.
    Any suggestions?
    Reputation: J.B. Weld's Avatar
    New cable and housing, if you haven't already.
    Yeah, cable and housing is new. Only thing not new is the rear der, which is going to be replaced in the next week when it arrives. My concern is the internal cable housing that the factor put in place between the cable stops leading into the frame. My concern is that it is compressing and leading to irregular shifting. I'm trying to factor everything else out before I address that though.
    Reputation: gmats's Avatar
    Apr 2005
    Try this. On the low side (I think that's your lowest cog (biggest gear)), give the limit screw an 1/8th of a turn in (limit the travel a bit). Now go back and start from the beginning and adjust the cable tension. And if this doesn't work, go the other way with the limit screw.
    I hope I can describe this so that the image makes sense.
    The shifter pulls a set amount of cable on each "click". On the first shift (from the slackest position), the shifter has to take up what ever slack might be in the cable (be in kink in the wire or flex in housing etc.). This means from the "limit" screw position to the position the shifter ends up pulling the derailleur to could be a slightly different "travel" then all the other shifts. By adjusting this limit screw just a small amount, it could make up for the difference you see in this barrel adjust position.
    Oh, and one more thing comes to mind when reading your "plight". I've found that when pulling the cable's slack out, do not pull too much. Do not pull real tight. I usually start with the barrel adjustment turned out from full slack about 1/2-1 full turn and cable taught but not too tight. Then I work the cable adjustment tension in with the barrel adjuster.
    The reason I do not pull the cable too tight as often while holding real tight and tightening the screw down, the derailleur can move off the limit screw which throws off all the adjustments there after.
    Hope that helps, hope you get it. Good luck, let us know how it works out.
    Reputation: sweatband's Avatar
    Jul 2013
    My first two thoughts are:
    1)chain length
    2)are your shifter and derailleur the same make?
    Jul 2013
    Another thought; make sure your derailleur hanger is not bent. You'll never get your shifting right if it is even a little. Even on a new bike they can get banged up from transport, loading unloading etc.
    Tried everything. It is still missing a shift meaning that t will take two clicks to move up one cog at some point in the shift leaving me one shift short at the end. Any remedy? Bad shifter? Bad derailleur? Too much tension?
    MTB B'dos
    Reputation: LyNx's Avatar
    YES, read and take heed! A bent hanger will give you hell until you get a new one or straighten the old one.
    Quote Originally Posted by psuambassador View Post
    Quote Originally Posted by sweatband View Post
    MTBR Member
    Reputation: ncfisherman's Avatar
    Yes, check the derailleur hanger alignment. Even a new hanger(separately or on a new bike) needs to be checked for alignment. When a hanger has less than ideal alignment, the cable tension and limits have less room for error making it more difficult to setup.
    One thing that hasn't been mentioned: Use an exposed section of cable(unless you have full length housing) to more accurately set your derailleur limits. Get the limits set close prior to pinching the cable, then pull slack out(just pull the slack, don't pull too hard) and tighten pinch bolt. Then check your high/low limits by pulling cable -- pull cable just enough to shift to the second smallest cog and check the shift to the high gear. You are looking for a quick/clean shift. Tighten or loosen limit screw as necessary in 1/8-1/4 turn increments.
    By using the exposed cable, you can also remove all the cable slack in the bike stand so you won't need to possibly add tension via the barrel adj over time. To do this, pedal forward while pulling exposed cable all the way out to reach the low/largest cog. Stop pedaling and then release the exposed cable. From there, just pedal forward so the derailleur returns to the high gear. After that is done, you'll notice slack cable if everything wasn't already completely seated in. Undo the pinch bolt and pull cable slack out.
    Jul 2013
    psuambassador, how'd you make out?
    Still working on it. I need to check but possibility that I used brake cable and housing by accident (picked up the wrong one off the floor). Going to try again tonight and see if that makes a difference. Thanks for checking in.
    My cable is all internal, which may be part of the problem.
    MTB B'dos
    I'm guessing if you used brake outer/housing that your shifting woes will fade a way once you install the proper compresionless shift housing/outer. Curious to read the update once you've checked this.
    Ok, I basically reinstalled the entire drive train, replaced der hanger, used brand new shifter cable and housing, removed and reinstalled cassette lubed everything up and ... it's still a no go. Actually worse than before. A couple of symptoms..once I start tightening things with barrel adjuster, towards the end, the shifting becomes really difficult and I can a very loud click in the shifter as I'm shifting. The shifter is not free at all. It feels tight.
    I'm wondering if the shifter might be bad or derailleur or what. Towards the end, the derailleur wasn't even moving anymore once I started moving the barrel so that it would go to the next cog. It just refused to move and shift to the next cog.
    I am starting to wonder if others were right about the frame, which is that the internal plastic piece put in at the factor actually screws the shifting up and must be removed. I really don't want to drill into the carbon cable stop so that I can run the full housing, but others have with success after suffering similar symptoms.
    I'm going to take it to my preferred lbs tomorrow. If they can't fix it, I think I'm going to get out the drill.
    Jul 2013
    Bummer! Good call with the LBS, but if that fails to solve anything, I would consider contacting the bike company (or ask the shop you bought it from to) before I drill anything.
    Stumbled upon this article...
    Internal Cable Routing | Sunset Cycles' Blog
    Feeling for ya. Nothing more frustrating than a ride thwarted.
    MTBR Member
    Sounds like you have a major issue somewhere.
    FWIW...brake housing actually works fine for shifters/derailleurs as long as you have a gear cable. Also, brand new hangers aren't necessarily in perfect alignment with the rear cogs -- a derailleur hanger alignment tool is needed to check that, whether a brand new hanger or otherwise.
    Hope your LBS gets that sorted out for you. Drilling a carbon frame sounds slightly nerve-racking.
    Yeah, I hope so too. I wouldn't really be drilling the carbon frame. I would be opening the internal cable stop a bit so that housing could fit all the way through. Wouldn't mess the structure of the frame as far as I know.
    In thinking about it, it's like my derailleur will only go through 8 speeds instead of 9. It will never go through the entire spectrum. If I get the tension enough to shift from the first to the second cog, it's not loose enough to back to the original cog. Hmmm...
    I would try running full cable and housing from the shifter to derailleur on the outside the frame, this would quickly confirm or eliminate the possibility of something wrong on the internal part of the cable.
    MTB B'dos
    What he said, quick, easy and you'll know for sure if it's anything to do with the cables. If that doesn't help, then try shifting the derailleur manually as suggested earlier using just the wire and pulling on it, if it shifts fine, then you know to start looking at the shifter. If that doesn't work, then disconnect the wire from the derailleur and pull on it and shift up and down, if the wire moves freely, then look to the derailleur. As said, just because you have a new hanger, doesn't mean that it's perfectly straight or that your frame is perfectly straight, you may need to straighten the hanger or bend it to make it parallel to the frame because of a slightly bent/damaged/mis-aligned rear.
    Quote Originally Posted by J.B. Weld View Post
    Turns out the derailleur spring was bad. Just told the shop to throw a new XT shadow on and get it ready to go. I'll be ready to ride by the end of the day!!!!
    Nevermind. They thought it was the derailleur but ultimately ran into the same problems I was having even after replacing the derailleur and shifter and housing and cable with all new stuff. They have deduced that it is a problem with the internal plastic housing, which was my fear. They are turning the problem over to the service manager who has 25 years of experience dealing with bikes on Monday. They say he will actually do the drilling if he cannot resolve the issue any other way.
    I have written to LT Bikes, the manufacturer, and have demanded that they reimburse me for the repair costs related to the error with their frame. Let's see how good their customer service really is.
    Sorry to hear about your difficulties (but glad you found a better shop)! Hopefully it'll get sorted out quickly.
    Mar 2013
    Fat chance on getting any money back for repair costs.. as with all these chinese frames, its hard to tell if even LT bikes is the manufacturer. Many claim to be, even though they arent. Which frame do you have? LTK023? and how long ago did you purchase it? It seems some of the earlier frames either had a flimsy internal housing or were routed wrong..
    Brand new. Bought through Lt bikes directly. I Dont have any great hopes and figured something would need done so I planned in the added expense. If they help me out even better. If not it's still a deal.
    Much to my surprise, I got a very prompt response from LT BIkes. They offered to fix the frame for free if I want to send it back or they are going to give me $50 towards the repair and $50 off my next order. I am very pleased and impressed with their customer service!
    Apr 2005
    That's great that you got to the bottom of the mystery. Glad you were able to get out and ride.
    Oh, bummer, read further down. So sorry to hear. Hope it all gets better.
    False diagnosis. Seems they ran into the same shifting problems that I did even when they put all new equipment on. The service manager with 25 years experience is looking at it today. Will probably have to drill the frame as I feared, but at least the pros will be doing it rather than me. Manufacturer already reimbursed me for the repair costs, so all is not lost.
    Jul 2013
    Wow, what an adventure! Glad a definate answer has finally materialized. Must feel good to know it was no fault of yours.
    Now, you know, a post ride report is in order...
    Right. They definitely nailed it b/c they ran the cable and housing outside the frame today and it was flawless. I have had a big ride planned for Thursday and praying that the bike is ready to go by then. Of course, there will be a post ride report after that!
    So the LBS fixed it! They drilled out the internal housing and ran full housing all the way through. I had them put on a brand new XT shadow derailleur and everything is working flawlessly. They actually said that the problem wasn't really with the internal plastic housing. Rather, the upper carbon cable stop was not made thick enough to properly function. In effect, it would flex when the cable shifted, leading to irregular shifting.
    The LBS was great to work with. I've been going there a long time so I have a good relationship with them. They only charged me $30 for the whole thing including new housing and cable and they put a ton of time into the project. I know that.
    Going on a short test ride tonight then a long one in the heat tomorrow. Can't wait!
    Jul 2013
    Well? How'd she do? How do you like it? What is the frame? Curious and interested about this carbon stuff... Especially if its an "off" brand...
    She did great! I didn't hold back at all. Pounded on her, jumps, steps, water etc etc. Awesome! The only drawback was her lightweight. I was getting thrown around by the trail a bit and the rear wheel was slipping up hill a bit, but I think that is just a matter or riding style. You can see my full review here: thedirtytire.blogspot.com.
    LT Bikes customer service was great too. Gave me $50 for the repair costs, only cost me $30. I will deal with them again. They were very responsive through the entire order and accommodating. I highly recommend the product and can speak highly of the experience (other than the shifting glitch).
    Jul 2013
    Just checked out your full series on the bike. Great reviews and great job. Looks like a real fun bike. Glad you are enjoying it!
  1. Shifting
    By FrigateCaptain in forum Beginner's Corner
    Last Post: 06-04-2013, 12:01 PM
  2. 2 x Shifting
    By dulyebr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2012, 06:49 AM
  3. 2 x Shifting
    By dulyebr in forum All Mountain
    Last Post: 04-21-2012, 01:47 PM
  4. Shifting?
    By ptfmb71 in forum General Discussion
    Last Post: 12-15-2011, 09:53 AM
  5. Shifting lag
    By Razorhog in forum Beginner's Corner
    Last Post: 06-06-2011, 11:30 AM
