Results 1 to 3 of 3
    shifting fine in middle ring but not in the granny?
    tonight i slo-mo crashed and landed derailleur side down. i thought little of it, as i was in the middle ring, and shifting seemed fine. then, when i went to the granny it was all mucked up-shifting into the spokes, not sitting on any sprocket, just not working. i went to take a look, and saw the bent hanger.
    i shifted back to the middle and it was fine again.
    why would shifting be okay in one ring but not in the other? if i had changed chain lengths, i'd think it was the length of chain causing the problem with the granny, but i just crashed...
    A Midwesterner in Europe
    Sep 2004
    You need to get the derailleur hanger bent back or replaced. It doesn't do it when in the middle ring because you chain is in a different spot, angled away from the rear sprockets.
    I'd fix the hanger, rather than risk more damage.
    got it
    i did bend the hanger back-i was worried i'd make it worse, but quite the contrary. thanks for the response-the shifting is again fine, for now.
  1. Chain skipping on middle ring of NRS
    By BobbyWilliams in forum Giant
    Last Post: 09-23-2007, 03:35 PM
  2. granny ring/mid ring size difference
    By ryanc44 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-14-2004, 12:47 PM
  3. middle ring upshift problem
    By gooberhead in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2004, 04:52 PM
  4. Replies: 2
    Last Post: 07-21-2004, 09:53 AM
  5. Front mech shifting problems
    By Ridders in forum General Discussion
    Last Post: 06-07-2004, 05:31 PM
