Results 1 to 2 of 2
    Shifting Efficiency on 2x10
    Hi.
    I'm building up my next bike and am stuck on 2x10 vs 3x10. I'm currently running 3x10 with 26-36-48 with 11-34. I practically never use my big ring so I'm interested in the idea of getting rid of something I don't need and instead going with the 2x10 (26-38 and 11-36).
    However, I wonder about the shifting efficiency of the 2x10. I ride trails with a lot of quick ups and downs with a need to decend and bottom out in a big gear and then hit the up with a lower gear. I usually keep the chain on the same cog on the cassette and drop down from middle to granny in the front to quickly get from a higher to lower gear in one shift.
    However, on the 2x10, I think that to accomplish the same thing I'd need to shift up in the rear several times, which doesn't seem as efficient.
    Or am I approaching this the wrong way?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by moldau94 View Post
    Hi.
    There is no difference in shifting between inner and middle rings of a triple and the small and large ring of a double.
    If you think the 36 vs 38t rings would be too much change just replace your current outer ring with a bash and be done with it.
    mtbtires.com
  1. SRAM 2X10 Shifting
    By Merost in forum Arizona
    Last Post: 05-30-2011, 08:44 AM
  2. SRAM X.9 2X10 Shifting
    By Merost in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2011, 12:10 PM
  3. SRAM 2X10 Shifting
    Last Post: 03-21-2011, 07:51 PM
  4. SRAM X.9 2X10 Shifting
    By Merost in forum General Discussion
    Last Post: 03-20-2011, 05:37 PM
  5. 2x10 Front Shifting
    By jared_j in forum SRAM
    Last Post: 01-03-2011, 01:49 PM
