Results 1 to 3 of 3
    Reputation: madsedan's Avatar
    Aug 2010
    Setting up my 1x10 and chain link question...
    I have the XT long cage and 11-36 on my camber, went to a 1x10 with 34t race face single speed.
    When I first did it my brother put the 34t crank ring to the outside of the crank spider on the stock FC-M552 shimano crank on the bike. I have had problems with chain drop using a fixed slx der so I bought a BB mounted MRP 1.x guide and mounted it last night.
    The chainring isn't centered up in the MRP guide unless I mount it to the inside of the crank spider, is that how I should have mounted it to begin with?
    Also, since I am no longer using a 44t ring should I go ahead and remove a few links of the chain, would it make throttle response and shifting a little snappier perhaps?
    Any advice on how many links is a good rule of thumb or should I wait until I go to a shorter cage der to mess with removing links?
    Will I be able to remove links without a special tool?
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Out spokin'
    Dec 1999
    Quote Originally Posted by madsedan View Post
    Yes
    Yes
    Don't wait. You can remove more links later if you buy a shorter cage der. Since you're running a 1x drivetrain, just shorten the chain as much as possible but still allows good shifting into the large cog. The cage should point a little forward when maxed out but not be level with the ground. Tensioned but not tight.
    No. You'll need a 'chain breaker' ... a special chain tool available at your LBS.
    --sParty
    disciplesofdirt.org
    Aug 2010
    Thanks man, my brother ended up having the tool so we'll do this today!
  1. Which chain stop for 1x10?
    By farmertan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-17-2011, 02:03 PM
  2. A little help please - chain quick link question
    By ncblue in forum Beginner's Corner
    Last Post: 03-21-2010, 06:41 PM
  3. Chain Link Question
    By blkss in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2009, 10:14 PM
  4. Half-Link Chain Question
    By JamR in forum Singlespeed
    Last Post: 03-21-2007, 10:07 AM
  5. Chain/Cog/Half-Link question
    By DiRt DeViL in forum Singlespeed
    Last Post: 01-30-2004, 05:43 PM
