Results 1 to 7 of 7
Thread: Seized up BB
    Reputation: tackleberry's Avatar
    Seized up BB
    I bought my Spec FSRXC used. The owner put a heim chain guid on it (3 ring). Apparenlty when it was put back together something wasn't done right and the drive side WONT come out. I am a pretty strong guy and I couldn't get the BB out. Worse, it started to strip out.
    Is their any way to get a seized BB out? Or should I start saving for that Coiler frame Ive always wanted?
    Old man on a bike
    You don't mention specifics on how you're trying to remove it but you do know that's a reverse thread on the drive side cup, right? What length wrench are you using? If it's truly seized you might try a good penetrating lube soak, maybe application of some heat, but a longer lever arm on your wrench can do wonders.
    suum quique
    Hold on while I bang my head into the wall....
    no didn't know it was reversed on the drive side
    Using a socket wrench with a park tools bb removal socket dealy
    I will go try to remedy what I have done
    thanks! I was about 2 days from getting out the hammer/chisel
    Good news...BB is out. Thanks a lot!
    I feel pretty stupid, but at least I'm not alone. A friend of mine did the same thing.
    Thanks again!
    (should've held out for the coiler)
    Old man on a bike
    Sometimes it's just a good idea to check the manual or do a google for something before you go hacking at it...there are other reverse threaded items on your bike, too.
    ps Isn't Tackleberry that guy from the Police Academy series?
    suum quique
    Jan 2005
    yeah, maybe have an lbs put install the new BB.. if you fuk up the threads of the bb, you will have to buy the coiler anyway
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by tackleberry
    ...I feel pretty stupid, but at least I'm not alone. A friend of mine did the same thing....
    it's not a very exclusive club congrates for working through the issues and resolving it
