    Scott scale and e type front mech problems
    Hi guys. I’ve just built my scott scale 10 and have a wee problem with the gears. When the chain is on the granny ring it rubs on the bracket of the e-type front mech. I’m running an xt front mech, sram 9spd chain and a 2007 xtr chainset. Are the shimano chains thinner than the sram ones? At first I thought maybe I had a spacer missing but I followed the instructions they say with the 73mm bb shell of the scale I should have no spacers in. Any help would be greatly appreciated.
    Thanks folks.
    rubbing - e type bracket
    Hi There,
    I too have a Scott Scale.
    I have the same set up as you except I am using a 2003 - 2006 M960 XTR Chainset and a Durace / XTR chain.
    No Rub!
    Have you checked that the spacing behind the bolt that locates the e type bracket is correct?
    Hope you get it sorted.
    Chaser.
    Good job!
    Quote Originally Posted by Chaser
    Hi There,
    Chaser.
    There was a washer where the mech bolts onto the frame, i removed it and it works a treat now!
    Thanks mate!
    E Type mech on Scott Scale
    Excellent!
    Enjoy your weekend - on the Scale hopefully eh?
    Chaser.
