Results 1 to 8 of 8
    Bonking ... not feelin' well safe to run shifter without barrel adjuster?
    I lost mine on my old shifter, don't really wanna get new one and LBS doesn't have any lol.
    Reputation: Nenbran's Avatar
    Dec 2010
    I wouldn't, unless there is another barrel adjuster at the derailleur. Otherwise, you'll be unable to fine tune the cable tension and your shifting will go to sh1t after the cable stretches.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Scarier View Post
    Will not work well. The barrel adjuster is also the housing stop.
    mtbtires.com
    It will be hard to tune without the adjuster...
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    How universal are barrel adjusters? My LBS has bins of old parts used for salvage. Look around and try to find a substitute.
    I don't rattle.
    Fat-tired Roadie
    Nov 2007
    If you don't need it for a cable stop, you can also use an inline barrel adjuster.
    Front shifting on one of my bikes is tuned that way. They're pretty common.
    i found 2 at the lbs today, bought some other items and they gave it to me. but man it's missing the outer tuning plastic knobs, so turning is really hard since it's just the barrel and a spring. But better than nothing. thank god.
    Plays with tools
    Reputation: customfab's Avatar
    Shimano shifters and RD's use the same barrel adjuster. It's also the same adjuster as the STI cable stops that come with road shifters. Most shops should have those around by the dozens.
  1. Shift Cable Routing on SMALL Rip 9
    By qcanoe in forum Niner Bikes
    Last Post: 06-14-2010, 07:44 AM
  2. Replies: 12
    Last Post: 04-25-2010, 08:42 AM
  3. How Hard is it to...swap XO grip shift for trigger shift????
    By Quantdude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-17-2007, 03:25 AM
  4. 2004 Burner and XTR shift cable routing
    By Greyeye in forum Turner
    Last Post: 04-04-2005, 10:09 PM
  5. Operating both Sram and Shimano trigger shift
    By glenk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-03-2004, 08:49 AM
