Results 1 to 6 of 6
    "Rumbling in highest 2 gears?........
    Installed a SRAM cassette, 11-32, onto an LX hub. When in the 11T or 12T gear, it is not smooth, seems very rough. The freehub splines do not extend all of the way to the outer end of the freehub. The 11T and 12T gears are not attached to the rest of the cluster. Should I have used a spacer, and if so, where would the spacer go?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by Dave B
    Thats interesting they should slide right on, are you shure the splines are lined up proper?
    Quote Originally Posted by dogonfr
    Everything is lined up, went on just like it should (seemingly), but still is very rough feeling when in the 11T or 12T rear gear, regardless of which front ring it is on. Doesn't make sense to me, either. New chain, cassette, hub, etc., this one has me stumped-nothing seems loose, everything lined up, lock ring is tight, but still is rough in either of those 2 rear gears.
    Jan 2005
    Get ahold of XSL_WILL & PM him the question, he has some excelent answers to stumping guestions or Call_Me_Clyd both are awsome
    MTB B'dos
    Reputation: LyNx's Avatar
    Describe "rumbling" for us, as it's not really a term I've heard used before to describe gears. Is it a 9sp hub? Which SRAM cassette did you get? I can tell you the PG950 doesn't use any spacers, not sure about the others. Is it the chain rubbing the FD and the FD just needs adjusting?
    I had the same problem
    I was running a SRAM pc69 chain. I just installed a Shimano HG93 the other day.
    A night and day difference. My 11 and 12T run just as smooth as the rest. I think
    Shimano makes a much better chain.
