Results 1 to 3 of 3
    Reputation: Paladin's Avatar
    Rohloff on a SOMA JUICE
    Will a Rohloff work with the SOMA JUICE? Any experience?
    Marc82Much
    Saint Louis, MO
    ups and downs
    Yes, but you'll need a speedbone for discs or a torque arm for v-brakes. You might want to consider a bolt on axle version to keep it in place in the horizontal dropouts.
    You could look at one of these Misfit diSSent frames, they have a Rohloff compatible dropout.
    On MTBR hiatus :(
    "What Rocky said..."
    I'd definitely get the bolt-on version for that frame, or any other with horizontal drops.
    And as appealing as it may seem, don't use the extended dropout in combination with a OEM axle plate for anti-torque duties. I've seen photos of standard horizontal drops twisted open by the torque from this hub. Stick with a Speedbone or ulgy torque arm unless the dropouts were designed with a Speedhub in mind.
    speedub.nate
    MTBR Hiatus UFN
