Results 1 to 2 of 2
    May 2005
    Rohloff hub and Blur VPP
    I have heard that the Blur exhibits some pedal feedback when riding in the granny gear. I was wondering if this problem would be corrected, or partially corrected if you ran a Rohloff speed hub on the back with a single ring on the front? My thinking being: you get a granny gear ranged gear without ever having to shift into the chainring that causes the pedal feedback.
    Any thoughts on this?
    Would using a speedhub have any other advantages or disadvantages with the VPP system?
    On MTBR hiatus :(
    That's my thinking.
    On my dw-link Hollowpoint, I asked a similar question of the designer, Dave Weagle, and he got back to me with a range of chainring and cog combos that would best match his suspension.
    However, a problem may arise if the designer intends the suspension to exhibit different behaviors in different gear combos, for instance stiffening the suspension in the granny ring.
    This is a really nice attribute of the Speedhub I run on my wife's single pivot Marin, where I was able to align the chain with the main pivot to give the bike fairly neutral pedaling characteristics throughout the gear range.
  1. Regrease hub bearings?
    By EJ_92606 in forum Wheels and Tires
    Last Post: 03-14-2005, 07:51 PM
  2. Maveric SC32 for blur?
    By savageracing in forum Santa Cruz
    Last Post: 02-25-2005, 01:39 PM
  3. Need a little help with a blur
    By sanger66 in forum Santa Cruz
    Last Post: 01-29-2005, 08:51 PM
