Results 1 to 7 of 7
    Rohloff Chainset
    I'm about to take the plunge and place an order for a Rohloff custom steel hardtail.(jeffson.co.nz)
    Does anyone have experience using a Rohloff with Middleburn RS8 cranks? I understand the ideal chainline is 54mm, what bottom bracket would I need to use to achieve this?
    Really looking forward to getting a Rohloff as most nearby trails are very muddy for 6 months of the year.
    So far these are the bike specs, any feedback welcome!
    Reynolds 853 hardtail frameset with EBB and Rohloff specific dropouts
    DT Swiss XR 4.2 rims
    Hope Pro II front hub
    Hope headset
    Middleburn RS8 crankset 38 x 16
    Formula Oro K24 brakes
    Rockshox Reba Team
    Music & Bikes
    Reputation: fokof's Avatar
    Check your chainline ( from middle of down tube to your plate )
    If your not at 54mm , adjust the lenght of the BB acordingly.
    If you have a 118mm BB and your chainline is 62 , use a 110mm BB , etc....
    You can also use spacers between your crankarm and the plate to obtain a perfect chainline.
    "There is a big difference between kneeling down and bending over" -FZ
    BB length
    For my ENO cranks, to hit the 54mm chainline, I needed a 125 symmetric BB. Length was recommended by Phil Wood employee and is spot on.
    Reputation: dosboy's Avatar
    whats the best chain to use with this setup a ss 8 or 9 speed?
    Music & Bikes
    If your a lightweight rider , you can use a 9 speed chain
    If you are a "big & padal masher" I would suggest SS or 8 speed chain.
    I use a 8 speed chain.
    thanks fokof i have an 8 speed chain on order appreciate the advice
    Slightly off topic, but as you're getting a custom build, have a think about Rohloff cable routing. With the EBB you have a range of options, including moving the rear brake caliper. See the following for details:
    Optimum cable routing for Rohloff?
