Results 1 to 3 of 3
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    Road cassete for mtb?
    Hey everybody!
    I have a spare set of wheels, and I was thinking that I can put some semislick tires on them, and different gear cassette for road riding (I don't doo much, but buying a cassette and a disc is cheaper than a road bike).
    My concern is if I could use the smaller cassette and just swap wheels when I think to do different rides. Since it's a smaller size, will the chainline be too affected?
    I have a XT rear deraileur now.
    <!-- / message --><!-- sig -->
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Quote Originally Posted by rzozaya1969
    Hey everybody!
    The chainline won't change because of the cassette, but the chain will be a bit too long with the smaller cog. If the max tooth difference in the back isn't too big, you can probably live with it if your XT is a long-cage der. The longer cage will wrap up the excess chain better. Just watch your gear combos so you don't get a lot of slack. Try it on a stand to see what gears make the chain too slack.
    You might see minor chainline changes if the hubs are different, but a small tweak to the der should fix that.
    Kathy :^)
    Look where you want to go. This is as true in life as it is in mtbiking.
    Bike to the Bone...
    Quote Originally Posted by Lucky
    Kathy :^)
    Kathy, thanks for your help.... I think I'll go that way... It will look funny having an 8" front disc on slick tires, but I don't care too much for looks
