Results 1 to 10 of 10
    Feb 2006
    Replacing Chains
    Quick question for you guys. I have always changed out my chains on the bikes every season just because the LBS recommended it for the spring maintainace. Anyways is this really necessary to do or is it just something that should be done when you start noticing the chain stretching or wearing out. Also how does this effect how well the chain meshes with the cog?
    Vaginatarian
    Quote Originally Posted by Albino84
    Hi Al
    there are special tools to measure your chain to see if its stretched or not, if you clean & lube it often (like every ride) and don't ride in mud too much it should be ok for more than 1 season(depending on mileage) if your gears are getting hook shaped replace them & your chain
    You don't need any special tools to measure chain stretch. They're 12" from the center of one link to one 12" from it. If it measures more than 1/16" greater than 12" then you likely should replace the chain. If it's 1/8" or greater then you might want to think about replacing the chain/cassette and rings. Kept properly cleaned and lubed a chain can last quite a while.
    Feb 2006
    Sounds good thanks for the quick replies!
    Devo
    Reputation: SelfPropelledDevo's Avatar
    pin wear
    chains dont actually "stretch". the pins start to wear. basically material is worn away from the pins, so cumualtivly it seems that the entire chain has "stretched". if you clean your bike regularly, a trick I've done for a long time, is to simply reverse the direction of your chain every time you clean it. I like to use SRAM or wipperman, cuz of the quick link, and i use a park chain scrubber with bio degreaser, run Pedros Super X chain lube, and the whole process is super quick.
    this practice can help reduce "cumulative wear" on the entire drive train. however...being that now those pins are being worn on both sides...well...i suppose its 2xdouble dangerous to break a pin, and we all know what that feels like when a chain staps. Doooohhhh!
    www.AsanaCycles.com
    "Bicycle Lifestyle, realized." D.G.
    Carpe Noctem
    Dec 2005
    I think Devo is on the right path but I have pulled apart many severely worn chains and I've never seen a pin worn in a visible way. I do however see the rollers wear on both the outside against the ring and cog and on the inside against the pin.
    Off season? What off season?
    Is there a way to measure the cogs to see if they are worn? No visible hook has developed in the teeth.
    I recently changed my chain but not the cassette and I noticed it now has the tendancy to overshift a bit then fall to the right cog when I downshift. I suspect the cassette needs replacement?
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by ahimanic
    Yes, Rholoff makes a tool to measure the cogs on a cassette. Sometimes you get those "hooks", and sometimes you don't.
    Carpe Noctem
    Dec 2005
    Quote Originally Posted by Jayem
    The Rholoff tool is certainly well built but because the tension applied isn't measurable it's inconsistent. Tho other downside is that although it can more or less tell you if the cog is worn it can't provide any quantifiable measurement, ie % worn. Has any one seen a more precise tool or measuring device?
    Au'Right!
    My 1 cent
    If you change you chain often it will help increase the time between having to change c/r and cassette. If your chain is kept fresh it (it'll be less worn) it will adversly affect the rest of the drivetrain less.
    Problem: "Bike has trouble going up steep hills."
    Fix: Recommend pressing harder on the pedals.
