Results 1 to 7 of 7
    May 2013
    Replacement crankset for Shimano-M570 (4bolt)
    I am working on a Diamondback X6 (circa 2000) with worn and bent middle and inner front chain rings.
    The current crankset is Deore LX M570 (22-32-44, 175mm) and I am having trouble finding replacement chainrings or a full crankset online stores or ebay. It must be ancient ?!
    Can anyone recommend an alternative crankset/chainrings I could buy & install?
    Reputation: uzurpator's Avatar
    Dec 2005
    I am 99,9% certain that any 104/64 4 arm chainrings will fit.
    Reputation: mitzikatzi's Avatar
    Shimano M442 Square Taper Chainset
    or
    Shimano Deore Chainset 9sp M590
    Often you can find entire cranksets for less than the price of all 3 chainrings.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    If it's a 4 bolt chainring then it is likely 104/64 and just about any replacement ring will work.
    If there is a community bike building/repair centre like Bike Again (Bike Again | Ecology Action Centre) here in Halifax, I'd go there first to find some used parts.
    Otherwise a good LBS should be able to order rings of all different BCD and tooth counts.
    Lastly, Jenson Shimano Deore-Lx M570/M571 Chainring > Components | Jenson USA Online Bike Shop has a replacement for your middle ring so if you just want to replace that, that might be a good option.
    Odd, that Jenson page seems to indicate it's a 5 bolt ring, but your title says it's a 4 bolt.
    May 2013
    Thanks for the response folks! @Slash9 I have seen the M570 offered in both 4 and 5bolt patterns, my version is the 4 bolt.
    I will take apart my chainrings this weekend and see if I can get replacements from my LBS, if not Jenson is next.
    Cheers
  1. GT Karakoram 2.0 Crankset replacement
    By scottiercox in forum 29er Bikes
    Last Post: 10-19-2013, 04:14 PM
  2. Is an XTR M952 or an LX M570 rear derailleur vintage yet?
    By rockhound in forum Vintage, Retro, Classic
    Last Post: 08-08-2011, 11:32 PM
  3. Hardrock '11 Crankset/BB replacement?
    By w4rp3d in forum Specialized
    Last Post: 07-12-2011, 10:26 AM
  4. BB / Crankset Replacement help
    By rjr19146 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-02-2011, 06:45 PM
  5. Shimano LX SL M570 shifter new cable problem?
    By donloder in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2011, 11:11 PM
