Results 1 to 2 of 2
    May 2013
    Replace RF Turbine Chainring with DH Single?
    Hello,
    I have an RF Atlas Crank and the 24/36/Bashguard Turbine Set. Is it possible to replace the 24er and/or the 36er chainring with one of RFs DH Single or another (cheaper) chainring?
    Yes, assuming same BCD. If you are talking going to 1X it is a good idea. If you are planning to retain the 2X then the DH rings will not have ramps or pins and could shift poorly. If you change the size of the 36, the bashguard may need to be changed to match.
  1. Replies: 0
    Last Post: 05-14-2013, 05:42 AM
  2. Need a new chain, replace chainring and cog?
    By jdinsj in forum Singlespeed
    Last Post: 03-20-2013, 08:39 AM
  3. Replace Chainring or Entire Crankset
    By SunnyinCO in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-22-2012, 09:14 PM
  4. What chainring to replace current one with?
    By subspd in forum 29er Bikes
    Last Post: 08-24-2011, 04:41 PM
  5. Race Face Turbine bolt kit for inner chainring
    By fernandoj in forum Vintage, Retro, Classic
    Last Post: 02-25-2011, 04:20 AM
