    Feb 2013
    Replace my BB92, with what?
    Folks,
    My Shimano BB92 pressfit bearings (on the non-drive side) are already grinding after about 4 months of riding. So soon? Indeed.
    Now, what should I replace them with? Is there something better out there for ~50 bucks? [I average about 100 miles a week, so maybe I should boost up to ceramic bearings? Did you? Are you glad? What did you switch to?]
    Anyone tried KCNC:
    http://www.<wbr>enduroforkseals.com/id256.html
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Collins View Post
    Folks,
    Anyone tried KCNC:
    Enduro. The bearings are replaceable rather than needs to replace the entire BB.
    Stay away from ceramic. Cost way more and require more maintenance.
    But I would just pop the seals off of your current bearings and repack before replacing anything.
    mtbtires.com
    lamer
    Reputation: llamma's Avatar
    Re: Replace my BB92, with what?
    I have an Enduro Zero PF30 BB, and the drive side bearing exploded on me after about a month. Replaced it with steel bearing and have been riding like for about 8 months. The remaining ceramic bearing is very crunchy, and I'm just waiting to replace it all with a better steel BB. My suggestion would be to not waste money on ceramic.
    Feb 2013
    Thanks for the advice. I'm not at all hip to the press-fits... Didn't even think to repack them. They *are* just bearings...
    After that, I'll try out Enduro.
    By the way, I figured I could rig a lag bold/nut to install the BB, but what should I use to remove, if I don't want to buy the extractor tool -- PressFit Bottom Bracket Bearing Tool Set -- which are 40 bucks?
    Thanks again.
  1. BB92 ebb?
    By bzo75 in forum Singlespeed
    Last Post: 12-10-2013, 03:53 AM
  2. Shimano BB92
    By zahgurim in forum Frame Building
    Last Post: 07-30-2012, 03:46 PM
  3. bb92
    By Pivot4 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2012, 10:53 AM
  4. maintenance: chain replace vs. drivetrain replace
    By mortenc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2011, 04:25 PM
  5. Shimano press fit BB92 and GXP press fit BB92 the same?
    By Stryder75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2011, 04:28 PM
