Results 1 to 2 of 2
    Renthal SR4 Single Chainring and RaceFace Light Bash guard?
    I want to run a single chainring with a RaceFace Evolve XC crank, Renthal SR4 34t chainring, and a RaceFace Light Bash. Is it okay if I use Problem Solvers Aluminum Single Chainring bolts? Or will the bolts be too short for both the chainring and the bash?
    Professional Bad Ass
    Feb 2007
    They will be too short. The RaceFace aluminum bash is about the same thickness as a chainring, so normal double chainring bolts should fit fine. The plastic type bashguards are thicker and will require a longer chainring bolt.
  1. Frame mounted bash guard for XX1 Chainring
    By onetothepowerofn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-12-2012, 02:57 AM
  2. Chainring bash guard?
    By shawnt2012 in forum General Discussion
    Last Post: 07-24-2012, 08:08 AM
  3. Need a chainring/bash guard
    By fiveoboy01 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2012, 04:33 PM
  4. Which chainring do I need to replace my bash guard?
    By Zackb911 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2011, 03:07 PM
  5. Looking for Bash guard for this Raceface turbine
    By mimi1885 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2011, 07:35 AM
