Results 1 to 10 of 10
    Nov 2012
    Removing XT crank
    Is removing a Shimano M780 24/32/42 (XT) 10spd crank pretty straight forward. I need to remove it to install a XCG 44t in a ISCG05 mount and couldn't find any videos on shimanos website or youtube. Do I just remove the crank arm and use a rubber mallot to dislodge the crank with shaft.
    Thx, Pete
    Yup, just like u said. It's a piece 'o cake. Good luck.
    whatever...
    Nov 2012
    got it. Wanted to make sure I don't need any special tools
    Reputation: in the trees's Avatar
    Mar 2005
    Remove the non-drive side fixing bolt (which will require a special tool), loosen the two Allen bolts at the end of the crank arm, and disengage safety tabs (if that model has them). It should slide out fairly easily.
    Nov 2012
    Where can I get the special tool to remove the fixing bolt and what is it called
    Thx, Pete
    Mar 2005
    This one?
    Universal Cycles -- Shimano TL-FC16 Crank Arm Install Tool
    I know that older models used this version.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by peter19ue View Post
    Thx, Pete
    It's a 'pre-load adjuster' not a fixing bolt. I put that in quotes because it doesn't actually adjust preload. The opposed M6 bolts are the fixing bolts on Shimano cranks.
    You can normally get it out with a pair of snap ring pliers or needle nose in a pinch. It's only supposed to be finger tight. It won't budge with the fixing/pinch bolts tightened down though.
    Nov 2012
    okay, it's a brand new ltc I'll be getting next week so I'll see if I can accomplish the task with just a pair of needle nose plyers. Thanks for all the help
    Mar 2005
    The Park BBT-9 has this tool on one end as well.
    Reputation: SpeedStarr's Avatar
    Thanks for the info on this. I am upgrading to XT cranks this weekend and was looking for this exact info. I did get the Park tool version for the "preload adjuster".
