Results 1 to 26 of 26
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Removing Freehub w/o removing cassette?
    I need to check the pawls on my I9 Torch hub. Can I pull the free hub off with the cassette still threaded on? This is using a SRAM 11spd XD driver. It seems like this should be possible . . . only reason is I'm being lazy and hate taking off the cassette.
    Reputation: Lone Rager's Avatar
    Dec 2013
    If the freehub just pulls off without the cassette, it'll pull off with the cassette. I've had freehubs that I couldn't slip back on without wrapping a string around the pawls to hold them in, which might be trickier with cassette still on.
    Do the math.
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Lone Rager View Post
    Yeah, I don't know about the installation bit and getting a cassette off when the free hub is not on the bike might be REALLY tough. Point taken.
    Class Clown
    Reputation: dundundata's Avatar
    sir have you tried the great pedro's vice whip, it makes removing a cassette something to look forward to.
    And if you don't have that wonderful tool use an old hunk of chain, an old towel and a lockjaw pliers. Or maybe just the towel and pliers.
    007 is offline
    b a n n e d
    Jun 2005
    Oh, i have all the tools . . . I'm just laaaaaaazy
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    The real trick is to get the freehub off without removing the wheel from the bike.
    May 2012
    I did this once, with this hub, on accident. I don't remember any issue putting it back together. YMMV
    Apr 2016
    Quote Originally Posted by 007 View Post
    Just pull and spin to the left.
    I do this all the time as i swap cassettes by changing the freehubs.
    Make sure pop end cap back into place on re-install
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Toot3344556 View Post
    Cool. I've got a bunch of spare o-rings too, since apparently they can shred when removing the drive side end cap.
    Apr 2016
    Never have I replaced mine but never had a problem. not sure if it needed to ever be done.
    A new hub is a BIOTCH to remove that end cap the first couple times...
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Make sure that you lube the end caps well to keep from shredding that thin, tiny "O" ring and to ensure you've sealed the bearings from dirt or water contamination.
    Removing Freehub w/o removing cassette?-20170318_184135.jpg
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Magically Delicious
    I found the XD Freehub endcap photos
    Removing Freehub w/o removing cassette?-20170122_160422.jpg Removing Freehub w/o removing cassette?-20170122_162105.jpg Removing Freehub w/o removing cassette?-20170122_162136.jpg
    007 is offline
    b a n n e d
    Jun 2005
    I still haven't tackled this job yet . . . in part, because as Toot noted, that end cap just does not want to come off!
    But I appreciate the tip on ensuring there's enough grease on there to act as a seal.
    Magically Delicious
    Part of the end cap removal problem prolly is because the internal "O" ring is dry and not wanting to release from the axle. Lubrication will facilitate the next removal. Mine were dry when I first removed them and they would not come off easy. I used a pair of Cannon plug pliers to grip the end cap and remove it without damage. Most folks prolly won't have these though.
    Name:  Cannon Plug Pliers I.jpg
    You might try wrapping a rag around the end cap (to prevent damage to end cap) and attempt removal with a set of regular pliers or Channel Lock pliers. But they will pull straight off the axle with a little effort.
    007 is offline
    b a n n e d
    Jun 2005
    I9 recommends a dowel through the axle and tapping it out that way. I'm just trying to find an appropriately sized dowel without spending $14 for a metal rod from I9. Have a run to Home Depot later today and will see if I can find a wooden scrap around that might work.
    Magically Delicious
    Hmmm... that's a new one on me. A dowel. Cool easy.
    A wooden dowel from the big box hardware store sounds easy enough
    Spherical Earther
    Reputation: Forster's Avatar
    Sep 2013
    Like my dad used to say "Sometimes the shortcut doesn't take you where you wanted to go."
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
    Spherical Earther
    Sep 2013
    Quote Originally Posted by noapathy View Post
    Cutting torch. No trick at all. Putting it back is the trick.
    Magically Delicious
    Putting the cassette back onto the hub with the freehub attached is really more of an exercise in gentle persuasion.
    An easy, counterclockwise rotation while gently pressing down onto the hub is usually enough to get all six pawls to smoothly engage. If you can't get them to engage by this method, you can take a pick (or something thin, even a butter knife) to push the individual pawls in while pushing down and gently rotating. Don't forget the freehub lubricant.
    Removing Freehub w/o removing cassette?-20170122_160938.jpg Removing Freehub w/o removing cassette?-20170122_161045.jpg
    Apr 2016
    Quote Originally Posted by Cleared2land View Post
    Well then I9 failed to properly lubricate the seal on both of my hubs...
    Magically Delicious
    Honestly, I have never seen end caps from any hub maker come lubricated. Undoubtedly, a good thing to do when you get any new component is to confirm proper lubrication. I want to ensure the caps are appropriately greased to provide an extra layer of protection for the bearings from water or dirt contamination. Just good practice.
    Apr 2016
    I hear ya but I expect more for a 3-400$ hub.
    Magically Delicious
    I understand your point. It's an end cap. I see this as a extra step that I choose to take to extending bearing life. There's no requirement to take this extra measure. Perhaps no different than ensuing that a bottom bracket exterior seal has the same additional grease to ensure the same extra measure of protection, yet none come with this. It takes but a few minutes to accomplish this.
    Perhaps your expectations are correct, but it's how many components are shipped with the expectation of the end user if they wish to go above and beyond. Tribal knowledge?
    Quote Originally Posted by Forster View Post
    Weld it back together. The new trick, functionality.
    West Chester, PA
    A piece of a tube works great for this purpose.
  1. Removing freehub body from hub with cartridge bearings
    By gurax in forum Wheels and Tires
    Last Post: 11-28-2016, 05:12 PM
  2. Problem removing freehub body from 2013 Mavic Crossride
    By omiTimo in forum Wheels and Tires
    Last Post: 02-23-2015, 06:37 AM
  3. Removing the XD Freehub Body from Easton EC90 XC Hub
    By thunderpants in forum Wheels and Tires
    Last Post: 09-13-2014, 09:40 PM
  4. Removing cassette
    By rubez in forum 29er Components
    Last Post: 02-27-2014, 03:05 PM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
