Results 1 to 5 of 5
    Removing bashguard from slx double, what size chainring bolts?
    So as the title says, I don't need a big ring and I don't really need a bashguard for the trails I typically ride. Does anyone know what size chainring bolts I will need for when I remove the bash? 6mm or 8mm? I was actually able to use the bolts and spacers from the crank to make it work but I dont want to leave it like that since it sticks out.
    Will this work? the "outer black 6mm bolts"
    http://www.universalcycles.com/shopp...ls.php?id=4904
    You can buy shorter bolts, or you can buy some spacers for the bolts you have. Long bolts with spacers, I have read, might provide a bit more strength than the shorter bolts used for single chainrings. Either way, it will be one or the other.
    ... And I Am You,
    And What I See Is Me!
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Quote Originally Posted by Wildeyes
    Are you positive on this one?
    Check out my SportTracks plugins for some training aid software.
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    Let's see. Buy shorter outer bolt set for a single chainring, or use what you have and buy spacers to take up the slack of not having an outer chainring or bashguard attached. Something I missed here? I used the latter on my 2x8 setup and it works.
    ... And I Am You,
