Results 1 to 13 of 13
    Reputation: bosbik's Avatar
    New question here. Regular drop out to Direct mount conversion?
    is it possible to modify the regular drop outs to make it compatible for shimano's direct mount RD's?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bosbik View Post
    It is the hanger, not the dropout. Modify? No. Replace with a direct mount? Maybe, check with the frame company.
    mtbtires.com
    my bad..i meant the hanger..so there is no way to modify the hanger to recieve a direct mount?
    Dec 1998
    No. Need a different hanger.
    mtbtires.com
    ahhh...so if someone came out with a hanger compatible with direct mounts then it would work right?
    Dec 1998
    As I said, check with the frame company.
    mtbtires.com
    Plays with tools
    Reputation: customfab's Avatar
    If your frame has a replaceable hanger it can be adapted to the direct mount system. If your frame manufacture wants to make the correct hanger. For some reason this format seems to be a little slow to catch on, besides being completely forward and backward compatible.
    Dec 1998
    Quote Originally Posted by customfab View Post
    Well, it is compatible only with Shimano Shadow RDs. I am not surprised there are few takers.
    mtbtires.com
    Plays with tools
    True, but it's not like an entire frame has to be built around it or it requires some cockamaney freehub driver to work. It takes a $10-25 hanger that in theory could be made for any frame with a replaceable hanger. There have been many ideas that are far dumber that have invaded frame design.
    Dec 1998
    Agreed, but I have not seen much of an incentive to do it.
    mtbtires.com
    Plays with tools
    Supposedly Shimano has had some issues with frame interference on certain bikes and that's what drove the new fitment. Basically the forward knuckle was crashing into the dropout or frame on some longer travel bikes. It also gets the derailleur out of the way during wheel changes and is a little stiffer, which is probably the biggest advantage to me. I'm tired of drivetrains shifting it 80% because it's got a flexy hanger that you can't do anything about.
    Dec 1998
    From my understanding, the overall position of the RD does not change. It just shortens the hanger (stiffer) and gets the more forward mounting bolt out of the way of the QR nut for easier wheel changes.
    If a shadow type derailleur hits the frame with a standard hanger, it would still hit with a direct mount. Can not really change the RD position without adversely affecting the shifting.
    mtbtires.com
    thanks for all the comments..learned a lot more
  1. Direct Mount FD Conversion
    By Redeye747 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-20-2012, 08:41 PM
  2. direct mount chain guide??? to replace direct mount der
    By TwoNin9r in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2012, 05:36 AM
  3. 9 spd Direct Mount FD
    By Salespunk in forum Ibis
    Last Post: 01-13-2012, 12:14 PM
  4. Help on direct mount FD for hd!!!
    By bayareaflip in forum Ibis
    Last Post: 07-07-2011, 08:43 PM
  5. MRP 1.X Direct Mount
    By olddirtygt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2011, 02:37 PM
