Results 1 to 2 of 2
    Feb 2006
    Reducing q factor on Shimano XT M760?
    Hey everyone, been reading a bit about this but can anyone do a more detailed "walkthrough" of how to reduce the Q factor on a set of Shimano xtM760 cranks?
    I really love these cranks and the external BB, but the Q factor (plus the eggbeaters I have on them) is a wee bit too wide for my liking.
    Any help would be appreciated.
    K
    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    You might be able to change the spindles on the eggbeaters to a shorter one (check Crank Bros website). That would change the pedal to pedal width.
    If you're running one of the new 2 piece cranks - there isn't much unless you want to start machining good cranks. If you're running one of the older 3 piece cranks (2 arms and a separate BB) you should be able to swap to a shorter BB to get a shorter distance... as long as Shimano is still making the BB in the right length.
    Good luck,
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
