Results 1 to 6 of 6
    Time to go farther
    Redline Monocog - What bottom bracket?
    I need to order a bottom bracket for my 2006 monocog frame. The BB on the complete bike is "VP Sealed Bearing Cartridge 68mm-116mm jIS"
    I have a square taper Shimano crankset but I don't know what length square taper UN-72 (or similar) I should get? Also what does the JIS mean?
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Common spindle lengths for square taper BB's are 107,110,113,115,118,122 &127 -- depending on the model of crankset you use.
    Just a guess --> JIS = Japan Industrial Standard
    Time to go farther
    Quote Originally Posted by Zanetti
    It's just a generic Shimano OEM takeoff crankset. Where do find the "required" BB?
    Or since I'm running it on a SS can I just run a 107mm and space the cog to match?
    Quote Originally Posted by Pivvay
    Does it have a number on it somewhere? Like FCM-xxx?
    A 107 would likely work, the only limiting factor is crankarm/chainstay clearance.
    Time to go farther
    It says FC-M440 on it. Thanks for the help.
    Time to go farther
    I installed a UN-73 68x107 bottom bracket. The chainring is plenty far away from the frame so even with a 36t I'll be fine. The chain is on the outside position of the crank. Hope this helps in case anyone else was watching the thread.
