Results 1 to 3 of 3
    Reputation: cyrix's Avatar
    Rear Derailleur issue
    I was riding today and noticed that after a few pedal stroke my chain would go incredibly slack and then all of a sudden pull back. Once I finished the final forward pedal stroke I looked down to see my chain just basically drop down between my wheel and frame only to have it pull tight again a few seconds later.
    What's causing this and how can I fix it?
    your freehub is dragging. most likely a seized or tight bearing. a service should correct this problem
    Quote Originally Posted by slidecontrol
    Thank you, I was a little concerned the dérailleur was going or something along those lines.
