Results 1 to 10 of 10
    rear deraileur jumping cogs
    am having problem adjusting my rear XO it seems to skip the 2nd cog when either down shifting & up shifting . I have got it to work but then it skips the third cog, what do I need to do to remedy this?
    Thanks syn
    Wrench
    Check derailleur hanger alignment and the limit screws. Is it the 2nd biggest cog or 2nd smallest?
    It is the 2nd smallest
    Check cable tension.
    I thought of that & did replace the old cable didn't help
    Aug 2005
    Second vote for checking hanger alignment. I was goin nutes this season adjurting by r derailier and having no luck. It was always skipping in the middle. Finally, went to a lbs that I don't normally go to and he pulled out the hanger adjustment tool and 30 seconds later. It was perfect........
    I have ordered a new hanger from santa cruz I don't want to mess with the old one with out having a replacement. The hanger should be here on the 2nd nov.
    I started having a problem with ghost shifting on the three smallest cogs right after a crash the other day. I thought the dérailleur was the culprit until I found a pinched chain link. On the larger cogs the chain was tracking around fine but on the little ones the pinched link would not bend far enough and was throwing the chain off the cog.
    Reputation: cantonkiddo's Avatar
    I was having this problem to and for the love of me, I couldn't fix it at all. I ended up bringing it to a LBS and they said it was cause the cable wasn't lubed up enough. :shrug:
    It is a brand new cable & the housing is only a year old, I am going to try some of the suggestions from here after work today I will let you know.
