    Feb 2006
    rear derailer problem
    I can,t get my largest to back clogs to shift smooth. I doesn't matter what front ring I am in the top three clogs jump around. It justs started about 2 weeks ago, I have been riding lot lately but nothing looks bent. I ride a 2004 rm slayer 70 xt rear lx front xt chain
    Old man on a bike
    What are you doing? Adjusting the cable tension? You might have a bent derailer hanger, very hard to tell by eye. Those would be cogs, by the way.
    suum quique
    On MTBR hiatus :(
    Not knowing whether you have a low-normal or high-normal derailleur, and without covering the whole derailleur adjustment process in detail, do this:
    Unscrew (CCW) the barrel adjuster 1/2 turn. Shift through the range of gears, being sure to switch between the small and middle rings of your crankset.
    Continue unscrewing in 1/2 turn increments until the jumping chain goes away. You shouldn't need more than a couple of turns.
    By unscrewing the barrel adjuster in these 1/2 turn increments, you are effectively lengthening the housing, which effectively shortens the cable. This process addresses any cable stretch (or housing / ferrule compression) that may have taken place in the time since the shifting was last adjusted.
    Screwing the barrel adjuster in (CW) would have the opposite effect, "lengthening" the cable.
    If you're interested, check out SheldonBrown.com or ParkTool.com for detailed step-by-step instructions on derailleur adjustment techniques.
    speedub.nate
    MTBR Hiatus UFN
    Feb 2006
    got it
    thanks for the input. It seems good on stand now I will ride thanks
