Results 1 to 6 of 6
    MTBR Mafia
    Reputation: cdub's Avatar
    Feb 2005
    Rear cassete keeps coming loose
    its a month old and it so loose that i can sway the rear chainrings on the cassete from side to side. i have been just taking off my tire and hand tightening the little plate thing on it. is there a tool or something that can help me to tighten it up for good.
    All Mountain was so 2005
    Quote Originally Posted by cdub
    I'd take it back to your bike shop to have it tightened...but yes if you want to do it yourself, you need a cassette tool and a torque wrench.
    born again
    Reputation: gearz's Avatar
    Hand tightening isn't quite enough...
    Just go out and buy the cassete lockring removal tool. Costs about five bucks. You really don't need a torque wrench IMO, just tighten the thing up fairly tight and call it good. While you're at the lbs pick up a chain wrench too as you need one of those to remove your cassete when it's time to replace it. Compared to what a shop will charge you, buying the tool and doing the work yourself is the only way to go....
    Classic Cascade Rides
    Original quote by Pinchflat:
    The faster you go the shorter the ride!
    MTBR Mafia
    Feb 2005
    great. I will go get it today. thanks for the help
    Tater Like'um Bike Ridez!
    Reputation: Ullrite's Avatar
    Is it a SRAM cassette?
    I also had a problem with my cassette coming loose. If the individual cogs are separating from eachother, and you have a SRAM cassette, take it off. Look on the back (side that faces spokes) and find the tiny little allen screw. I had mine come loose on 2 diff. cassettes (both SRAM) and that wreaked havoc on my spokes (as it worked its way out, the screw actually shaved little notches in my spokes as I was coasting) and caused all kinds of rough shifting. Now I loctite that little bastard right out of the factory box every time I install a new cassette. Haven't had the problem since. Only problem I've found with the SRAM cassettes too, btw.
    SEEK THE GNARL, LEST IT FIND YOU FIRST.
    Mar 2005
    I did the same...
    Buy tools and feel pride in wrenching on your own ride....
    Only way to do it...
  1. x-type cranks coming loose
    By newton in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2012, 07:10 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. 2.1 - 2.2 rear tire for dry, sandy, rocky, loose conditions?
    By Earthpig in forum Wheels and Tires
    Last Post: 07-22-2004, 07:16 AM
  4. XT rear hub keeps coming loose
    By Innocent Bystander in forum Wheels and Tires
    Last Post: 06-16-2004, 07:40 AM
  5. rear triangle is loose
    By yellowwducky in forum Ventana
    Last Post: 05-17-2004, 07:06 AM
