    Feb 2012
    Is a Racrface Granny Ring Spider needed for a Turbine 24t inner on RF Chester crank?
    Is anyone running a Raceface Chester or similar crank with Turbine 10speed chainrings in a triple set-up? ( 24/32/42 ). Do I require a Granny Ring Spider Kit to install the 24t inner chainring?
    Race Face 2013
    Need some help!!!
    Reputation: Reelchef67's Avatar
    hi have chester cranks with turbine rings, 22/36/bash.
    You do not need a spider kit
    Feb 2012
    Thanks, did your cranks come with a spacer of some sort for the inner ring? NO spacer of any description in my box.
    No spacer required or supplied..
    " I don't ride park"
  1. Replies: 0
    Last Post: 05-14-2013, 05:42 AM
  2. Replies: 8
    Last Post: 05-05-2013, 05:12 PM
  3. Can I use a RaceFace Turbine 10 spd middle ring on my 9 spd system?
    By ziscwg in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-31-2012, 08:20 PM
  4. 22T granny ring for a XTR 950 four bolt spider, does it exist..?
    By patineto in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2012, 12:28 PM
  5. Crank with a flat spider, or 74mm big ring?
    By rocwandrer in forum Fat bikes
    Last Post: 10-19-2011, 12:29 PM
