Results 1 to 5 of 5
    Apr 2005
    RaceFace + shimano
    hi folks:
    Anyone knows what chainline yields a 2002 prodigy xc square tapered crankset mounted on a 113mm long shimano BB?
    Anyone has tested this combination with proper shifting performance on a 9speed shimano drivetrain?
    Thanks,
    Josť Luis
    Chrome Toaster
    Reputation: Hecubus's Avatar
    They are not compatible. Shimano uses octalink bottom brackets and raceface uses ISIS drive. They look slightly similar but are completely different and completely incompatible. Unless you are refering to the square taper kind but as far as i'm aware prodigy cranks never came in square taper.
    Apr 2005
    thank you for your reply;
    yes i meant the square tapered version. The crankset is dated 2002 i think....
    Get your freak on!
    Quote Originally Posted by pepin
    Can't help you with the chainline, but it will work fine. As long as the chainrings aren't too badly worn, it will have no problems.
    Chrome Toaster
    Didn't know that. I thought the Prodigy came out after RF had moved over to ISIS completely. In that case a 113mm BB spindle will yield a 50mm chainline on a square taper cranks. 110mm will yield the standard 47mm chainline. In the case of splined BB's which have a deeper insertion depth a 113mm will yield a 47mm chainline and 116mm will give 50mm.
  1. New to the sport, need bike :)
    By iLLestOne in forum Bike and Frame discussion
    Last Post: 05-13-2005, 06:28 AM
  2. shimano xt or raceface atlas?
    By gwm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-03-2005, 10:35 PM
  3. Shimano LX M580 vs RaceFace Evolve X-Type
    By r1Gel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2004, 11:24 PM
  4. Very Old Shimano 7 speed replacement
    By NFields in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-27-2004, 04:30 PM
  5. Beginner, want a FS bike, which one?
    By Rich4757 in forum Bike and Frame discussion
    Last Post: 05-31-2004, 07:40 PM
