    I'm a bottom feeder...
    Reputation: CARP's Avatar
    raceface diabolus crank ??? Please help!!!
    Hello All-- I have above said crankset and I have no problem getting the drive side arm off using the dustcap as a crank puller but how in the heck does the non drive side come off??? Once I remove the drive side, the non drive side seems like it doesn't want to come out of the BB shell. Any help would be greatly appreciated.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Give the spindle a smack with a rubber mallet from the driveside. And then it should just pull out. There are too rubber o-rings that sit pretty tight on the spindle.
    Thanks...
    Thanks... XSL_WiLL I wanted to do that but I thought I'd ask before trying to force someting. The instructions don't really give a good explaination of removing the crankset other than reversing installation... Anyway thanks again and I'll let you know how I make out... CARP
    how do you pull off the drive side crank?
