Results 1 to 3 of 3
    telemarc
    Jan 2005
    RaceFace Deus X Type Bolt backing out !!
    My crankbolt on my crankset keeps backing out. I have tried Blue locktite, let it sit a couple days and it still backs off enough I have to stop every hour and tighten it or the crankarm works it's way loose.I heard this was a tolerance problem with the first run of these and I may have got one. Any ideas??
    Driven by watts inside
    Reputation: - Jeremy -'s Avatar
    Sounds like a tolerance issue to me. I had a problem with my first set of Deus. No matter how much torque I put on the crankbolt, the driveside crank arm would still wiggle slightly. This caused the chain to rub on the front derailleur.
    I created an RMA through their website and sent the crank arms in. They sent back a new set in about 1-2 weeks.
    Give them a call or pop on their website. I'm sure you can RMA those.
    - Jeremy -
    Chrome Toaster
    Reputation: Hecubus's Avatar
    race face crank coming loose.
    Try this. If still no go, warranty.
  1. Replies: 3
    Last Post: 04-14-2005, 08:52 AM
  2. RaceFace crankset advise: Deus or Turbine LP?
    By Daniel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2005, 02:40 PM
  3. RaceFace Deus X-type
    By cadence90 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2005, 09:19 AM
  4. Shimano Octalink Cranks bolt type
    By hhemmerde in forum Tooltime
    Last Post: 06-17-2004, 01:26 PM
  5. Raceface Deus, what tool did you use to install it with?
    By Ratt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-13-2004, 01:19 AM
