Results 1 to 10 of 10
    Sep 2004
    race face sig ti bb ?
    race face signature ti isis bottom bracket question: i have 2 of these - one i had for ~ 3yrs, and then another won on ebay w/in the last 7-8 months. both have developed play. can i swap the bearings out? will this be the fix? do i need completely new bb's? if i can swap out the bearings do you have the specs on what i need to get? can i get them at a local bearing supplier or are they proprietary?
    i seek, therefore i hope to find....
    thanks.
    ride fast...take chances...
    i don't give a shift
    Reputation: collideous's Avatar
    Signature Ti BBs use 3804 bearings. If you have play it's most likely the bearings. I doubt a local bearing supplier will have them stock. Enduro Bearings has a list of dealers though.
    blogging @29in.CH
    Sep 2004
    ok...how do you replace the things? someone has to have done this...right?
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    RF has special tools to take apart & reassemble the signature BBs. My LBS has the tools so they did if for me.
    Quote Originally Posted by CraigH
    Can anyone post a picture of the tools needed to remove bearings from the RF Signature bb? I have new bearings for my Signature Ti but haven't managed to remove the old bearings yet. There are some kind of rings on the spindle between crank and the bearing, right? Do I need to remove these first and are they attached by just tight fit?
    I've never seen the tools as when my LBS changed the bearing on my BB he did it in the back service room in about 10 minutes.
    Ok. I guess I need to figure out something. Or use a sledgehammer...
    Since you are in Europe, what about seeing if RF's European distributor has the tools to change the bearings?
    Grasping for Air
    Reputation: nanorapture's Avatar
    Dec 2004
    instructions from Enduro
    Titus
    here is a tutorial to let you know what you would have to do to change those BB bearings:
    http://www.enduroforkseals.com/siteb..._bb_instr1.pdf
    Those instructions are for the RF X-type BB, not Isis like the OP has.
