Results 1 to 6 of 6
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Quick ? regarding removing cassette TOOL.
    I have a Sram cassette, is this the tool I would need to remove it? What do I do, just put this on, and loosen the lock ring and the cassette will come off?
    http://www.pricepoint.com/detail/210...p=325%20PARLR0
    Or is something with a "guide pin " better?
    http://www.pricepoint.com/detail/146...p=325%20SETLR5
    Also, would I need a chain whip, or could I hold the cassette with a rag or something?
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Depends how tight its on there... Proper tools for the job is always a good idea, you'll probably use it again and again...
    Mountain Man Dan
    What tool would be better?
    Don't matter. I have two cassette sockets and neither have a guide pin.
    Mountain Man Dan
    Ok. Great. I should probably pick up a chain whip too.
    meow meow
    Reputation: b-kul's Avatar
    yes get a chain whip. you can probably do without but it makes it so much easier.
  1. Removing the guide pin from a cassette tool
    By Wombat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2011, 03:41 AM
  2. Removing shock from 575 - special tool?
    By Earthpig in forum Yeti
    Last Post: 08-29-2010, 04:34 PM
  3. Removing this cog - what tool?
    By Chris N in forum Singlespeed
    Last Post: 09-07-2006, 11:55 AM
  4. What tool do I need for removing a rig freehub?
    By Badgerboy in forum 29er Bikes
    Last Post: 04-23-2006, 10:56 PM
  5. Pump, patch kit, tire levers, multi tool, CASSETTE TOOL?
    By Mighty Drop Off in forum General Discussion
    Last Post: 04-13-2005, 08:21 AM
