    quick question bout derailluer
    whats the diff. between a long cage and short cage der.?
    thanks
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    Quote Originally Posted by jungle_rat
    thanks
    Duh the size of the cage. The cage is the part that hangs down and has the pullys on it. A long cage can pick up more chain and is reqired for most mountain bike gearing. A short cage is used on road bikes and is thought to shift quicker
    Quote Originally Posted by Maida7
    THANK YOU....MAIDA7
    mechmann_mtb
    Guest
    you can also get away with a short cage if you are running a 1X9.
    the length of the cage determines how much chain slack your RD can pick up. a long cage is necessary to allow enough slack chain to run 27 speed and for suspension travel.
